Hoping someone can help me, dishwasher stopped mid-cycle, all LEDs dead. There is water in the bottom of the compartment, if I empty it out with a cup it refills and then the float valve shuts it off, so there is electrics to some parts.
I have checked the door switch - all OK. Then examined the PCB, no signs of damage or any burn marks. I removed the Main Switch on the control panel and checked the terminals for continuity :- there are six pins, I found that there was only continuity between pins 1 and 2, also 3 and 4, but nothing between 5 and 6 - could this be the problem ?
I would much appreciate any advice on this or whatever else the cause could be.
Ian
Ian
