- Joined
- 14 Mar 2016
- Messages
- 3
- Reaction score
- 0
- Country
This is an odd one! The machine works fine for a few weeks then the motor stops working completely, ie drum does not turn at all. No fault codes, fills and drains etc fine.
Same process each time:
Confirm the fault, pull the machine out, remove the back, test it again and it works fine!
I've changed the brushes, cleaned the motor, cleaned the plug, checked the wiring and pulled it around in case of a break somewhere. But nothing will reproduce the fault.
When pulling it out, I did not even turn the drum. (However, previous occasion I did try rotating and wiggling the drum before pulling in out, with no results)
Has me baffled so far!
Any ideas welcome.
Any ideas welcome.
