Have a Bosch Max 1000 WFL 2000 front load WM which will more often than not stop usually before the spin cycle. The "READY" light will be aluminated as if it is ready to start program again. Could this be a Logic fault or something simpler?
Not familiar with your machine, but I would check door lock & switch, the pump & any filter, motor brushes & pressure sensor & pipe before looking for a pcb fault.
