British Gas WR1 wireless thermostat
Discussion in 'Plumbing and Central Heating' started by paul130861, 11 Oct 2011.
  1. paul130861
    11 Oct 2011
    5
    Thanks Received:
    Country:
    My rooms stat does not seem to talk to my reciever and the only way I can get the heating to work is to press the override button on the reciever. The recieve alarm light is also perminantely lit. I have changed the batteries in the room stat but it makes no difference. Somebody said I have to reset the recieve????? How do I do that. HELP!!!!!!!!!! I run a BnB and the guests want the heating on.
  2. DeltaT2
    24 Aug 2011
    1,400
    Thanks Received:
    165
    Glasgow
    Country:
    I take it Paul it's no longer under guarantee?? If so, good give them a call to come out & fix it.
    If not, they use re-badged controls, so your best option is to take a digi photos & post them up here. If you're really stuck, you can link out the receiver to give you some heat, but don't attempt to do anything with the electrics if you don't know what you're doing!!
    HTH
    • Thanks Thanks x 1
  3. Whitespirit66
    15 Dec 2007
    8,011
    Thanks Received:
    753
    Bristol
    Country:
    It's a rebadged Drayton Digistat SCR.
    Try this. If it doesn't work, check battery terminals are clean. Still not working.................new stat time.
    1. Turn off the power supply to the Digistat SCR (receiver unit)
    and leave for 5 seconds.
    2. Turn on power to SCR unit and check red light is on.
    3. Press override button No.2 and check the green light comes
    on and boiler fires.
    4. Press & hold down button No.1 (Keep depressed), then
    press No.2 and keep depressed. {The Red LED light will flash
    a couple of times and then it will go out}
    5. Now release both the buttons – {the two LED lights should
    come back on}
    6. Get the Digistat+2RF/+3RF unit and stand two metres away
    from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
    7. Remove the battery cover and fit the batteries.
    8. The Red LED light on the SCR will now flash for approx. 7
    seconds.
    9. This confirms that the radio signal is being sent and
    received.
    10. The Digistat+2RF/+3RF and the SCR are now successfully
    linked by a dedicated RF address
    • Thanks Thanks x 1
  4. danielleedavies
    20 Oct 2015
    Thanks Received:
    Country:
    I've tried everything and the thermostat is linked but when I press override number 2 (step 3) the boiler doesnt kick in? The hot water works fine and the boiler fires up. Any ideas anyone?
  5. ollski
    8 Oct 2003
    5,461
    Thanks Received:
    126
    Birmingham
    Country:
    Green light comes on and no heating usually means the receiver is faulty but depending on the type of system you have it could be the valve controlling heating / hot water which is usually in the airing cupboard near the hot water cylinder. Have a look and tell us what you have and we can advise further.
Loading...
Share This Page
