Once, in a factory, we had an electrolyte pipe burst under considerable pressure ... having killed the pumps, we watched the leak rise in a graceful arc to engulf the overhead buss-bars .... lightening like flashes .. molten metal flying ... scary !!
Oldbury power station had to change down a coupla gears !!
We work on a site with large busbars, switch fuses, and mccb panel board busbars in a large room. This room is also full of compressors that are as noisy as........
When we kill the compressors for maintenance, it is scary how much 'buzz' you get - main incomer feeding these busbars is rated at 1200amp, currently fused to 800amp
I have never seen this definition listed, but I have always assumed that the term is derived from omnibus, meaning "encompassing or including all." i.e. a bar which is a common point between many or all circuits.
... The electrical engineering term "bus bar" - a substantial, rigid power supply conductor to which several connections are made. This was once written "'bus bar" as it was a contraction of "omnibus bar" - a connection bar "for all", by analogy with the passenger omnibus - a conveyance "for all"....
