- Joined
- 1 May 2008
- Messages
- 4
- Reaction score
- 0
- Country
Dear All,
Currently upgrading my kitchen and naturally leaving the pros to handle the electrics, new consumer unit etc. The sparky hasn't been assigned to the fitting team yet, and I want to get some of the new cable runs through now, leaving just the tails to be hooked up by the qualified expert in due course. I don't understand enough about diversity and ratings to safely determine the cables I can run through.
Q. To ensure compliance with the regs, can anyone please advise on the suitable cable to use for the following:
Induction Hob - Duel fuel (2 rings, + 2 gas rings) - both induction rings would be in use at the same time quite often.
Left ring front: Ø 16 cm, 1,4 kW,
Left ring back: Ø 20 cm, 2,3/3 kW,
Nominal load: 4,6 kW
Connected load: 2800 W
Nominal current of fuse: 16 amp
EAN code: 3838942702662
Length of run from main board at least 25 metres.
Off the same cable (within 3 metres of the hob) a junction box to supply 2 x low power LED lights and
an extractor hood, within ca.2 metres of the junction box :
Connected load: 190 W
EAN code: 3838942525865
Then a separate run of cable from the main board (replacing existing wiring) ca. 4 metres to supply:
A new oven:
Oven consumption (conventional operation): 0,87 kWh
Oven consumption (venting operation): 0,79 kWh
Connected load: 3300 W
EAN code: 3838942782534
with a junction box to supply a warming drawer:
Connected load: 400 W
Nominal current of fuse: 10 amp
EAN code: 3838942523922
Grateful for any advice.
Al
A new oven:
Al
