cable size
spx
19 Mar 2004
Can anyone advise on cable size for mains downlighters - I want to install nine 50w downlighters and I'm within the 1200w bracket.
I've bought a load of 1mm wire but i'm not sure if I should use 1.5mm
what would you recommend?
1mm is fine for your purposes. Here is a cable size calculator should you need to know anything more: here
BTW, you mean 1380watt limit? 230*6 ?
Used to be 1200 watt ( 240*5), but supply voltage is now 'officially' 230 volts, and the 5 amp MCBs replaced with 6 amp MCBs.
That cable size calculator is poo. I just manualy checked the results at random, and it is off by quite a bit in several cases.
1.0 is fine unless the lighting cuircuit is much larger than would be seen in a normal house
most sparks seem to prefer to use 1.5 though
I dunno, manually checking TLC's calculator, telephoning suppliers to check up on conversations with other posters... Dude, you have way too much time on your hands! :cool:
See this from the cable calc in question:
QUOTE:
Caution - for Guidance ONLY
NO guarantee as to the accuracy of these values is given.
And they should be checked against some other source.
UNQUOTE.
thanks guys - put my mind at rest, didn't fancy a fire! :LOL:
1.0mm2 is fine,
1.5mm2 is normally used in houses in case the customer wants to install some additional lights.
Therefore the cable can then handle the extra demand without re-wireing.
Dingbat, what I do and why I do it is my business fella. If someone at a supplier or manufacterer gives out potentially dangerous information or advice, I will take whatever action I feel necessary.Incidently, I am sure I get at least as much work done in one day as you. I am able to manage my time, and as I start work about 7am and finish normally about midnight, I am sure that I do more than you.
That is the effing problem in this country today, to many people accepting of cr*p cos they would rather watch TV.
This is correct if the MCB in the ccu is 6A, may be i missed something, if this is not a new circuit it may be that the MCB is 5A, than the limit will be 5*230=1150w...
FWL_Engineer said:
Dingbat, what I do and why I do it is my business fella....
Well I shall consider myself well and truly put in my place. Just as you, by processes clearly way above my understanding, know so much about my comparitive worth, I should have realised intuitively that your hectic pace of life leaves no room whatsoever for a sense of humour. Perhaps, when you get a moment, you could try and lighten up.
PS: I was being jocular, by the way - I imagine that's another thing that you are much better at than me.
PPs: As is having the last word... :)
PPS: I am, however, better at spelling :D
securespark said:
Let's not get too personal....
That was, kind of, my point. But if we're going to play nice in the school yard we all have to play nice otherwise it's back to, "my dad's bigger than your dad," all over again. Anyway, there goes the bell...
DINGBAT
You are playing that game, by saying "I'm better at spelling"
And it is getting personal.
One man's weakness is anothers forte.
Nothing wrong with my smelling...I am lightened up...but your post was not exactly jocular when read if that was the way it was meant..
Oh well, I think we both have better things to worry about anyway..Oh look, The grass is growing!! :D:D
