What makes you think that a short length is more likely to overheat than a long length? What's the physics behind that?mrscalex said:Does anyone know if there is a minimum or recommended length of cable to use when daisy-chaining modules in a grid switch? Eg 2" might work but 6" is recommended to avoid over-heating a short length etc?
Thanks.
AdamW said:I suppose the only important thing is that there is enough cable to ensure that they aren't under tension.
I am wondering, due to the short distances involved, is it better to use singles within the grid rather than T&E? Would certainly look neater IMHO, but would also make installation easier and therefore ballsups less likely
AdamW said:Scalex, did you get the pre-printed modules for kitchen appliances? If so, how much were they? I can only find the non-printed ones on the websites I know, £3.55 for a 20A DP.
plugwash said:and getting standed cores into the terminals may be trikyier than solid cores
