Hi
I have a 50w single oven, 4 hobs, it is only small, 50 cm wide.
To be fair, i don't even cook much, so will this fit into a standard plug socket or do i have to pay an extra £200 to get a 30A socket installed?
As it's an electric hob, you still have a problem.
Typical electric hotplates are between 1 and 2 KW each, so with four hotplates and the oven, that could be about a 6 to 8 KW total load. That's around 30 Amps, far too much for a 13 Amp plug to cope with!
Follow the link below and looking at the instruction booklet says the rating of the oven is 1950W, but the four rings total another 5800W so unfortunateley a 30A supply is the only way to go.
