Can I use emulsion on metal?
5 Oct 2006
Birmingham
There is a removable metal box on my wall which covers some pipework, at the moment it is just in bare metal.
The walls are painted in Dulux Almond White and the box has to match the colour of the walls.
Could I use emulsion on the metal box if I were to prepare the surface correctly with a primer?
I know Dulux do Satinwood for wood and metal in this colour but I don't really want to buy a tin of this because:
a) it may not match the walls
b)it seems a waste just to paint a small box approx 7" x 2"
Claire
If you were to use metal primer first then you could use emulsion over the top of it but if knocked it may scrape off. I'd use satinwood personally as i dont think the colour would be that far off, you would only notice the difference in the finish in that satinwood has a slight sheen.
Or if you went to a Dulux Trade centre you could get Almond White in a flat oil finish so it would look the same as the emulsion but it would be expensive for what you want!
