I have had two cases of the drain water pump not running.
Each time the pump itself proved OK but the circuit boards both suffered similar failures. I replaced the first board, all OK for about 18 months then same failure.
Circuit boards are both labelled 1/475540/BC ivensys.
Looking at the component side top LH; Transistor T3, Resistors R12, R13 burned out. No obvious fault on the track side. The machine worked OK except for no drain.
Can anyone identify the burnt items, they are too charred for me to read their ident or colours.
