Hi guys
I've got 3 existing solvent weld pipes (2", 2", 1.5") coming from an upstairs bathroom, through a cemented hole in the wall and dropping down into a 4" horizontal (slight slope of course) that runs along the top of a corridor, then drops outside. The smaller pipes join the 4" with strap on solvent weld bosses.
Two of the bosses are leaking (either not enough cement? or maybe Wickes brand?), so I've pulled them off and am replacing with more robust looking ones from a proper plumbers merchant. The downpipes have been cut when I removed the old bosses.
Problem I've got is that all three downpipes, and the 4" pipe are all quite rigid as a complete assembly and there's hardly any movement, so I can't just pull each pipe back in turn and put new fittings to re-make the connection. There's not an inch or so of play in the pipes. What I'd like to do is assemble the whole lot together, but everything needs to go together at the same time, and the cure period of the glue won't allow that!
I was thinking of preparing two pipes to almost join end to end, then splitting a 2" joiner lengthwise and putting it over the join. Problem is if I do this the pipes are not entirely lined up straight, so I see further issues.
Does anyone have an idea, maybe if there's slow-cure glue available? or possibly some way of joining without needing to have so much play in the pipes?
Thanks so much! (got people coming to stay over Xmas and wife insists this bathroom must be usable!!!).
Dave
Dave
