can't move pipes to use compression joint!
Discussion in 'Plumbing and Central Heating' started by rdhanjal, 7 Nov 2010.
  1. rdhanjal
    8 Mar 2007
    22
    Thanks Received:
    Country:
    Hi folks
    I'm really stuck at the moment.
    I've just located the leak we had. It was under our bathroom floor. Looks like a screw was rubbing on a radiator pipe.
    It's right under the toilet, so i would have had to rip that out, as well as the ceramic floor tiles, plywood and floorboards , maybe even the bath too (!).
    That is why i opted to cut out the kitchen ceiling below. The pic below shows the kitchen ceiling looking up to the bathroom floorboards.
    [​IMG]
    The problem I am having is that i just can't move either end of the pipes to make the compression joint fit.
    There's no give at all. Probably because the pipes tee off to rads and the lack of space in the joist notches.
    Does anyone know what my options are?
    Is it possible to solder a coupling on by sliding it all the way over one pipe before sliding it back??
    I'd appreciate any help i can get...!
    cheers
    Rob
  2. PlanetThanet
    6 Mar 2007
    211
    Thanks Received:
    12
    Country:
    File out the 'stop' on the fitting and turn it into a slip coupling.
    Thanet.
    • Thanks Thanks x 1
  3. seco services
    3 Dec 2007
    15,656
    Thanks Received:
    1,248
    Essex
    Country:
    as you say a solder coupling yes you can get a slip e/f coupler.
    • Thanks Thanks x 1
  4. 45yearsagasman
    14 Mar 2010
    5,891
    Thanks Received:
    1,035
    Norfolk
    Country:
    Yes you can use slip couplers either soldered or compression.
    • Thanks Thanks x 1
  5. picasso
    8 Apr 2008
    7,695
    Thanks Received:
    1,695
    Essex
    Country:
    You can file the stop out of the compression fitting or use a couple of 22mm slip couplings and solder the pipe.
    • Thanks Thanks x 1
  6. picasso
    8 Apr 2008
    7,695
    Thanks Received:
    1,695
    Essex
    Country:
    bloody hell fourth :eek:
  7. seco services
    3 Dec 2007
    15,656
    Thanks Received:
    1,248
    Essex
    Country:
    must be an echo.
  8. gassafeengineer
    6 Oct 2009
    1,983
    Thanks Received:
    290
    Cumbria
    Country:
    bit of hose pipe and 2 jubilee clips is cheaper :LOL: :LOL: :LOL: :LOL:
    "come on Neddy next job YEEEE HAAAAA"
  9. rdhanjal
    8 Mar 2007
    22
    Thanks Received:
    Country:
    Thanks for the replies, I knew people were helpful on this site, but still shocked at how quick you all got back to me.
    Many thanks.
  10. libby lou lou
    16 Oct 2006
    3,733
    Thanks Received:
    43
    Lancashire
    Country:
    Theyr'e bored that's all, missus don't want to know. :LOL:
Loading...
Share This Page
