Catnic Lintel Installation - DPC & Drip Holes In Mortar?
Discussion in 'Building' started by EViS, 15 Jan 2013.
  1. EViS
    15 Jul 2008
    424
    Thanks Received:
    2
    Country:
    Is this the correct way to install a catnic lintel? Or are the DPC and 'drip holes' unnecessary? Anything else which should be included as part of a installation?
  2. stuart45
    13 Sep 2008
    2,258
    Thanks Received:
    253
    Somerset
    Country:
    Weep holes go in the perps.
  3. noseall
    2 Feb 2006
    24,933
    Thanks Received:
    1,618
    Staffordshire
    Country:
    Erm....your (lower) image is showing bricks UNDER the whole lintel.
    There are no bricks under the lintel only under the bearing ends.
  4. EViS
    15 Jul 2008
    424
    Thanks Received:
    2
    Country:
    Haha! Yes, I got carried away with the copy and pasting :mrgreen:. Have now edited.
  5. EViS
    15 Jul 2008
    424
    Thanks Received:
    2
    Country:
    Should they be the entire height of the perp? And how common is it to use weep vents such as these?
    [​IMG]
    That shows 'mortar thickness', so unsure how they are used in conjunction with a brick facade, or a rendered one for that matter as surely the rendered wall will have lots of small holes all over the place.
  6. limerockconstruction
    29 Oct 2012
    506
    Thanks Received:
    69
    Bristol
    Country:
    The type you show is fine, but there are also manufacturers who do the full height of the perp sizes as well, thats what my local merchants sell.
    You sit them flush with the front of the brickwork - it may look a little odd if your looking hard, but it looks much nicer than a puddle in the cavity!
    As for the holes in the render, same thing really, they end up pretty flush with the front of the render, and only in certain places, ie over windows and doors where your attention is much more drawn to the item under the lintel as opposed to the vents above!
  7. ^woody^
    3 Sep 2006
    17,818
    Thanks Received:
    1,964
    West Mids
    Country:
    Plastic weep holes are marketing gold.
    How they have managed to persuade people to buy and use these is amazing.
    Leaving a joint out is obviously not good enough. Never mind the fact that moisture seeps out around the outside of the plastic weep holes, between it and the brick or lintel it sits on!
    • Thanks Thanks x 2
  8. EViS
    15 Jul 2008
    424
    Thanks Received:
    2
    Country:
    Ok, I see that how you finish a weep hole is arguable, but good to know that one is recommended.
    Should a weep hole be created at each far end of a lintel? Slightly inwards? Or should there be more than two (depending on the lintel length) and spaced 'x' mm apart?
  9. limerockconstruction
    29 Oct 2012
    506
    Thanks Received:
    69
    Bristol
    Country:
    depends on the size of the opening....I think regs say 900mm, but I would still have two even on a smaller opening.
Loading...
Share This Page
