Caulking
Discussion in 'Decorating and Painting' started by malcolm622, 7 Apr 2012.
  1. malcolm622
    14 May 2007
    25
    Thanks Received:
    Kent
    Country:
    I recently put new skirting in the house and screwed it well to the wall. On the gaps between the top of the skirting ad the wall I put plenty of felxible decorators caulk (two layers allowing the first to dry). However, a few months later. The caulking appears to have shrunk leaving gaps - how do I prevent this from happenning?
    With kind regards
    Malcolm
  2. dcdec
    14 Jan 2011
    1,465
    Thanks Received:
    408
    Hampshire
    Country:
    Did you prime before caulking? bare timber (and plaster) will draw moisture out of the caulk and make it shrink. That said its funny stuff and different brands seem to behave better than others
  3. malcolm622
    14 May 2007
    25
    Thanks Received:
    Kent
    Country:
    Hi
    No I didn't - I was not aware that there was a need to!
    Malcolm
  4. dcdec
    14 Jan 2011
    1,465
    Thanks Received:
    408
    Hampshire
    Country:
    Most likely thats the cause then
  5. opps
    16 Jun 2006
    1,904
    Thanks Received:
    222
    London
    Country:
    As DCDEC suggested they all seem to vary. If however you want something that will remain flexible and shrink less then look at products such as CT1, it does cost more though.
Loading...
Share This Page
