Last week my Potterton Prima 30F central heating boiler blew the main fuse. I didnt have a spare 3 Amp fuse, so fitted a 5 Amp, which also blew. I then called out a a local heating engineer who traced the problem to a faulty pump, which he replaced (and chargerd me £200!)
Since the repair, the central heating pump runs constantly, even if the boiler is not running. I contacted the engineer who fitted it, who suggested that the pump over-run thermostat may be damaged. I have since checked this (by dipping the probe in hot water) and it is switching OK.
The boiler also seems to be only partially controlled by the timer switch- it follows the preset CH + HW settings, but also has also started firing up in the middle of the night or if the temperature dial on the front of the boiler is turned up.
Does anyone have any suggestions? Would a higher rated fuse have wrecked the PCB?
Many thanks
Jim
Many thanks
Jim
