My central heating system is about 30 years old , but has had a new boiler, about 7 years ago, It it now having the following problems.
1. The pump sounds like it is pumping gravel. Increase the speed and it gets louder.
2. When the system comes on we get a lot of banging for about 10-20 mins then it calms down and all you can hear is the pump.
3. There are 3 radiators that you can't bleed at all. Ie open the bleed valves and the air hisses for a second, out but no water comes out. Then nothing.
4. Also open the main bleed valve and no water comes out and does not hiss.
5. The other radiators bleed but water doesn't rush out.
6. None of my radiators on the ground floor come on until you turn the pump speed up. But I still get no. 1, 3, 4.
Hot water works.
Boiler is Warwick, pump is a myson unit 3, 6 rads upstairs, 6 downstairs.
Any clues what could be wrong?
Hot water works.
