I have a problem with the Central heating and water not getting hot.
System:
Gravity feed system, with H configuration and 3-port valve, Baxi Boiler, no drain off points except from radiator. No pressure gauge. No flling loop.
History:
System has worked fine for past three years, when I removed a radiator, I suspect air got into the system, pump became noisy, rads and water would not heat. Plumber replaced pump, saying it had failed, although I now suspect it had lost its prime. A week later pump ran but no hot water/rads, same plumber called again, said it was a loose connection in boiler causing it to trip out. Plumber got the system working and a week later it failed again, the over temperature switch had tripped on the boiler.
Spoke to plumber he said H configuration pipe work needing changing….lost faith with plumber. The loose connection was a red herring. As a Spark I later checked out boiler electrics no problem found. After further investigation it appears that the system looses its pressure. If I bleed a radiator then the system will loose pressure and result in no water/rad heat despite running pump (boiler over temp kills pilot light).
Action:
Header tank is full to brim. I have put cleanser through system and sludge inhibitor.
I opened 3-port valve and blasted system with hosepipe until water runs out of header tank overflow, bled pump and rads. System will run for around two weeks and fail due to loss of pressure.
Concern:
Water system top up via header tank is on feed side of pump so I’m not sure if pump inhibits the gravity pressurisation of the system (I am not sure that this has ever worked).
Note:
Plumber said that the H configuration has tendency to suck air into system via vent to header tank, but this had never happened until I took radiator off, so doubt it.
During the summer the system will happily run heating the water, only when I try to run CH does it fail.
Suspect:
Water pressure top-up failure due to pump?
Sludge builds up on radiator circuit return?
Air locked system?
Any clues would be greatly appreciated.
System:
History:
Action:
Concern:
Note:
Suspect:
Air locked system?
