Cheapest way to put a new back door in
22 Jan 2010
Sussex
Hello guys,
I need to put a new back door into a refurb that I'm living in. Whats the cheapest way to get a new door in, its currently a 140 year old wooden door which needs replacing. Is wood the cheapest option or is a case you get what you pay for?
wood is cheaper and better than plastic. Also more secure.
However plastic doors are very profitable, which is why so many companies are keen to sell you one.
I prefer hardwood, and treat it all over with Cuprinol clear, plus paint those parts of the frame that you will not be able to reach afterwards, before fitting. But a lazy cheapskate will not bother.
Get a competent local joiner to fit it for you. You will probably need a new frame as well, and this is usually more economical than fannying about trying to repair and plane an old one. At 140 years old your old frame is probably rotten, warped, riddled with holes for old locks and bolts, encased in cracked old paint, a non-standard size, and fitted with rusty hinges in screws that won't come out. Allow for 3 new hinges, preferably stainless, mortice rackbolts top and bottom plus a mortice deadlock or sashlock. He will fit them in very little time if done when the door is going in, faster and neater than most DIYers could manage. If you buy the parts yourself they will not cost much, but make sure he is not expecting to supply the lock at retail prices as he might have calculated this as part of his profit margin.
Yeah but the OP asked 'what was the cheapest way'
A bespoke hardwood door and frame as at 140 years old it won't be off the shelf = not cheap
A local joiner = £120 a day at least
3 stainless hinges, ball bearing type i assume = not cheap
Mortice bolts
Mortice sash or deadlock
Then a weather bar and a storm guard, then the stain etc etc
This sounds expensive, a pvc door would be cheaper if its just a refurb
an off-the-shelf wooden frame can be cut or planed (if too big) or wedged and foamed (if too small).
Then an off-the-shelf door will fit.
If he's too mean to buy hardwood he can buy a softwood one. If he's too mean to buy stainless hinges he can buy BZP ones
http://www.screwfix.com/p/rack-bolts-and-key-pair/49530
http://www.screwfix.com/p/sterling-5-lever-mortice-sashlock-brass-2-64mm/74484
or
http://www.screwfix.com/p/5-lever-bs-3621-2007-mortice-sashlock-brass-2-64mm/97131
example
http://www.wickes.co.uk/tamar-2xg-glazed-pine-door-1981x762mm/invt/204240/
show me the price of your plastic door, including frame, fitted. Will this be a standard-sized door and frame, or special order?
How much do you have to tuck away for repair when it goes wrong?
Upvc door made to measure fitted £450-£495
John, my post was a bit tongue in cheek, anyhow, standard or not most pvc Installs are made to measure so there is no price increase unlike with a bespoke timber frames. Also I Don't quite get what you mean when You say 'tuck away for repair when things go wrong', the door will have a 10 year guarantee, what would happen if a M & T fails on your timber door?
Posted from phone
Thanks for the advice guys.
Still not money for a door so I'll continue with other things for the moment.
James
