Check valves
6 Mar 2007
Hi
Could any of you gentleman plumbers (like myself :LOL: ) recommend a decent quality check valve with a bore larger than a pencil and will not 'buzz' when used :evil:
I have had a couple of jobs recently with gravity hot and mains cold. Have steered customer away from monoblock taps as much as poss but have still the need to fit mono. Combine the flexi tails with the check valve and the flow is carp. I have some good large bore ballofix but the checks all seem focused on mains application.
Thanks.
Thanet.
Could any of you gentleman plumbers (like myself ) recommend a decent quality check valve with a bore larger than a pencil and will not 'buzz' when used
Nope, they all seem to be identical inside. :evil: All you can do is put two in parallel, say a 22 and a 15. The littlum stops the bigum buzzing and gives better flow.
