cladding - looking for ideas on what to use
4 Apr 2013
hi
as part of house renovation we will be removing the old tiles off a small old extension on back of house, construction is timber upper frame as in the photo (which is the bit we want to clad) and lower/ ground floor is brick.
area to cover is approx 18m2 including sides and short sloping roof
We need to remove current tiles as we need to replace windows and insulate the cavity between outside and inside and will only be replacing the larger of the two windows as the small one is no longer needed.
obviously cost is a consideration so looking at options and for your suggestions.
have considered upvc but wondered if there are any tiles or corrugated sheeting options available, something that would stand out.
thanks d
GALLERY]
Marley board is much better than pvc in my opinion and probably cheaper.
I would be wary of something bonkers unless your house is quite contemporary, in that case go nuts.
If it was mine i'd do it in cedar, if i could scrap the money together...
hi thanks guys
yeah that marley weatherboard looks just the job and simple to fit.
as i plan to cover frame with plywood, do you need to batten before fitting the boards or can you fix straight to the plywood.
will have a read of the marley pdf files on fitting etc. later
thanks again
