Hello, i've looked at all the radiator issues on the site, but nothing quite covers the same problem i am having,
please bear with me as this is my first post.
i have 3 radiators upstairs, 2 downstairs. the nearest one to the boiler (GAS) is the bathroom however this is only warm at the bottom and cold at the top... bleeding i hear you cry, but there is no valve like the other 4 to do this... ?
the next closest is bedroom 1, this radiator heats up fine and is hot.. after i bled it.
the next is bedroom 2, this is stone cold. the pipes in and out are warm/hot however, i've tried bleeding this one also and there is no trapped air.
then there is 2 downstairs both of which heat up fine.
i have just moved in a week ago and am renting from an agency. but i would like to learn and fix the issue myself as when i come to having my own place. i know what to do..
any ideas etc?
many thanks
--- edit ---------
I'm starting to believe there is a blockage in one of the pipes. but the location of the two suspect rads, doesn't tie up. why would downstairs and one upstairs work and the nearest rad not, and one in middle in terms of closeness not work either.
I've tried balancing the system but no joy,
--- end edit --- thanks --------
any ideas etc?
many thanks
--- edit ---------
