Hi all, just thought I would post my problem on here before calling out an engineer. Hopefully it's a problem I can fix to keep the price down as its not a good time of year to be paying for unnecessary work to be done.
Ok we have a Potterton Promax HE Plus combi boiler which has been installed for around 6 or so years. The problem is that when we run the hot water taps or shower we get a very loud banging from the boiler. It really does sound like someone rattling the pipes in the heater cupboard. The water then runs cold and hot. It simply fades temp to hot then back down to cold in a continuous cycle until turned off. We have had the same issue around a year ago but it simply went away. There is no banging at all if we just run the radiators.
There are no leaks that I can see and the noise sound like it's coming from inside the combustion unit but it's hard to tell. I am competent in most DIY and Electricals but I won't mess with Gas. So if the problem is related to the gas side of things then I will need to get a Gas Safe engineer out. It would however be helpful to have an idea of the possible faults.
Any help appreciated.
