We were lucky enough to inherit a Worcester boiler with our house (28i Junior to be precise). Never had a problem with it, or the CH system.
Bled a top of house radiator sunday night as the top wasnt hot, no probs there, didnt check the boiler pressure afterwards though, and Monday morning the missus had hold/cold shower as the boiler didnt work properly due to low pressure (the noise of the air in system woke me up).
So carefully topped up the system to 1 bar, no problems. Came home from work 9 hours later, same pressure of 1 bar (so i dont think the mains valve is open at all).
However, when the system is on the pressure rises to 3 bar (when it red lines), i dont recall it ever getting that high before when running.
Q1) Should I be concerned about this? Do i need to do anything?
Q2) Could it cause damage to the boiler?
I mention the boiler make/model as i am sure that there will be a pressure release valve, and i can see a plastic pipe leading to the shower waste water pipe, so it shouldn't explode! But I want to make sure...
Thanks for any advice and tips people, you could save me a significant plumber call out charge with your advice!
