Combi giving alternating hot/cold shower - usual reasons?
15 Mar 2011
Sussex
Hello folks
We've just moved into a completely refurbished bungalow. It's 3 beds, a little over 1000sq ft. A completely new heating system was installed, using a Worcester Greenstar 37CDi Combi. I can't pass comment on the CH system, but although the HW works fine at the taps it is impossible to control the temperature of the showers with the mixer valves, veering from hot to cold all the time.
Having searched through these forums for this issue, I have drawn the conclusion that it's unlikely to be a boiler fault on this brand new system, but could be one of the following:
1) Too much of a pressure mismatch between hot and cold at the shower mixer valve.
2) Not enough flow rate through showerhead causing boiler to constantly turn itself off and on.
3) Oversized boiler, resulting in it going constantly off and on same as (2)
The HW temp is currently set to 'e' on this boiler - which is the setting between 4 and 6. This may mean something to someone familiar with these boilers. I presume the 'e' means this is regarded as the most efficient temperature to set to.
Any comments or advice welcome. Thanks.
I thinbk that you will need a competent heating to come and help you.
But first try turning a tap on half flow as you run the shower.
Tony Glazier
Just an update on this - I've tried running the shower valve on max flow, and this does mostly stop the fluctuations - so this would indicate that with a slower flow the boiler is turning on and off all the time. But running the shower valve on full flow is not practical - the water blasts all over the place. (We have very high mains pressure here)
Anyone any ideas about this ?
Because temparature are warmer now, try and see if turning hot water dial on boiler down a little makes a difference.
