Compact 100 glow worm boiler
1 Jan 2016
Hi I have a compact 100 glow worm boiler my hot water and heating work separately but not together help and diagnosis please
Sorry my heating is not working at the moment but the hot water is pressure is on 1bar (black arrow) but the red arrow is on 3 is this causing it?
Sorry my hot water is working but my central heating is not, my pressure is fine and I am using a Honeywell thermostat which is set on continuous running for both at the moment
Usually leaked water from the spindle of the hot water proving switch into the microswitch causing a permanent demand for hot water.
Thanks does it mean I would need a callout or is this something I can fix myself?
Ollski how do I fix the constant demand for hot water? Would I need to change my zone valve actuators for the heating?
I changed the valve but still the valve for the heating doesn't open
Help?
I thought that he was going to call a pro?
Tony
