Concrete slab as finished floor
2 Sep 2014
Norfolk
Hi all, I'm doing some work to my barn - including a small kitchen extension. Current spec is 100mm hardcore, 50mm sand blinding, DPM, 85mm celotex, 100mm concrete slab, DPM, 75mm screed.
I've done a few concrete pads in my time and am very happy with the finish I get bull floating, there is nothing to be hidden in the screed so my question is, can I do away with the screed and just have the slab as my finished floor to tile over? Will obviously save me a lot in time and materials.
Thanks in advance!
No underfloor heating? Really? Not even to 'future proof'?
Even then you could put the pipes in the middle of the slab, and float. Or skim it over with self levelling.
I can confirm that tiling over a basic floated slab takes twice as long as over a well laid screed. Well it did me!
Any depth saved on the screed should be seen as an opportunity to increase the insulation :idea:
Your spec is slightly unusual. Floors are normally specified as insulation over slab - which requires a screed - or insulation under slab - which does not. Sometimes a screed is used to make up levels and produce a clean flat surface. But in that case it would normally be a thinner bonded screed - 30mm or something like that. The question is; why would anyone add a 75mm screed directly onto a concrete slab? It's unnecessary.
