CONDENSATION IN NEW EXTENSION LOFT
8 Dec 2006
Hello all, i was in the attic of my new extension tonight and noticed there quite a lot of condensation on the roof felt. It's of the breathable variety but there are no vents to speak of as i thought they would not be needed.
The question is it normal to get higher levels of condensation just after plastering, rendering etc or should i install vents etc. The loft i currently only half insulated abd there is an airtight loft hatch installed.
Thanks in advance.
It's important to have an airy loft to control the condensation, as the heat rises, the moisture got nowhere to go but onto your roofing felts, they are many ways of doing the ventilation and my opinion is use a ridge vent tile at the top and the soffit which allow circulation of air movement
Cheers for the reply, i was told that the breathable felt didn't neet vents but after reading the forums i'm starting to wonder.As or the plastering etc is it normal to get higher levels, there was quite a period wher the loft was open to the rest of the house which won't have helped. I didn't see any or very little before the plastering though.
Cheers
I have no idea how good the breathable felt are but you can't beat fresh air via the air vents.
Most likely the damp from your plaster caused this, best to wait when the plaster has dried then have another look at the loft.
Thanks for the replys mate, i'll give it a clean down with a cloth and keep an eye on it, as soon as i can i'll put some vents in as you suggest,fresh air can't be beaten.
Cheers again
