I have a perfect second hand Siemens standard double oven that needs to be connected to the existing wire coming from the existing cooker socket on the wall. What connection do I use to connect the wires together?
First things first.
Do you know the power rating of the appliance and the size of the electrical cable and fuse/breaker?
You will also need to know if you have earth continuity with regards to safety.
