connecting a single electric oven
hub
1 May 2004
I have just purchased a gas hob with an electric oven.
I have a connection from a previous electric oven already in place which is a 32amp double pole with additional socket.
The rating on the cooker is 2380w,is there anyway i can use the existing supply or will i need to run another supply to accommodate this
you can change what you have to either a fcu, or socket, then plug in your oven
Thanks breezer
so put a 13 amp fused spur before the existing unit
sorry i mean to say plug the oven cable into a 13 amp fuse spur which is being fed from socket on the existing 32 amp supply
sounds messy to me. a better solution may be to fit a 20A MCB to the circuit instead. (If this is possible).
Although connecting the cooker to the connection unit as it stands is not ideal, it wouldn’t be a huge issue.
personally i would replace the cooker connection unit with a socket and plug the cooker in.
it is better not to wire in an appliance that comes with a plug because the mantinance technicians are often not allowed to work on equipment that is wired in (basically they are not qualified to work on fixed wiring and they are not allowed to work on an appliance without doing some testing first and/or disconnecting it from the mains)
if there is a socket on the cooker control unit i would keep the breaker as it is if not i would downrate to a 16A
cooker control unit
Thanks all for your prompt reply
Ive decided to run the existing supply to a fused 13 amp pole switch to a double socket,
thanks all again
if you are useing a socket there is no need for a FCU as sockets are designed to be fitted on 32A cuircuits
i was a little concerned about the 32amp supply thou, if the cooker only requires 13amps is it best to have a fuse that size to be on the safe side
I am doing the same thing with the oven.
It is supplied with a 13Amp fused plug
I have a 30Amp independant cable ending at a cooker connection unit via the cooker control unit.
I agree change the cooker connection unit for a plug socket, and just plug it in.
You've got your answer then. So why go resurrecting a post thats FOUR YEARS out of date? :rolleyes:
