OK understood, but what you should have done in IMHO was post a new thread explaining what you have done and how you fixed your issue, may have got more comments.,
It was the lack of a clear technical solution on this thread that led me to pop the top of the cylinder and work it out for myself.
I am aware that the previous thread comments ceased last summer, but I don't agree that buying a replacement product counts as having resolved the problem (on a DIY forum).
Best regards anyway.
Des
In your first picture there is a big white bit and a big blue bit, you need to replace the big white bit, there is a seal at the bottom which has perished.
Not the best description i grant you, but i hope it makes sense.
They got it in by fitting the mechanism and base still attached to each other into the cistern.Surely I'm missing something as they got it in there? I must be able to get it out some how right?
Here is what to do:
Remove the whole MacDee unit with a quarter turn anti-clockwise as described earlier in the thread. You will notice 4 backets on the top of the big white sealed cyliner. You can carefully pop this open with the base of a tea spoon (being careful not to crack the unit).
Inside you will see its a very, very basic design with what is effectively a bicycle brake cable from the push button unit, pulling on a little pully device which lifts the plunger at the base. The trouble is that the pully /plunger assembly is on 2 guide rails on the inside of the unit and it gets stuck and gravity can't pull it closed after you press the button.
Here's what I did:
I cleaned the guide rails with some tissue and smoothed them down so any limscale residue and gunk was gone. I then sprayed a load of WD40 onto the guide rails and the pully mechanism and then pulled on the cable repeatidly to get the WD40 to move around and do its buisness.
(Maybe this bit was overkill but I also disconnected the cable on both ends and cleaned the visible parts - the was some gunk and, after taking the spray diffuser off the WD40 can I forced a whole load of WD40 down inside the cable sheath - again pulling the cable a couple of dozen times to move the WD40 around.)
It has been perfect ever since.
I fully expect it to go wrong again in a few months but 5 minutes of diy and a couple of squirts of WD40 later it will be sorted, and that's better than spending £15.99 on another piece of potentially defective plastic.
Good luck all with this! Please post any positive or negative results.
Des
Guess What?
My blooming flush mechanism has jammed again a couple of times.
I might have to climb down from my high horse and go and buy another unit. The prospect of spending 20 minutes every two weeks wasting my time on this poxy flusher doesn't seem that appealing any more.
WD40? Whose stupid idea was that? oh.....wait a minute.
Arrrgghh!!!!
Des
