- Joined
- 27 Jan 2008
- Messages
- 23,663
- Reaction score
- 2,666
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have two D-SLR cameras a Pentax K10D and a Nikon D7000 the Pentax has bundled software Pentax Remote Assistance 3 which came with it, the Nikon has third party software SM Tether.
The Pentax software has many more features to Nikon but both allow time lapse and use of bulb setting for long exposures.
I started with Pentax software and it at first would not work with Vista then I found has to be started as administrator same applies to Nikon one over this hurdle I still had problems where the Pentax would only work when set to Jpeg in RAW it always failed. Found if RAW set to DNG rather than PEF then 9 times out of 10 it worked but unreliable.
Set up an experiment taking time lapse of garden and worked well until light levels fell as it reached 1/6 second the program failed and I realised all problems were related to available light.
The Nikon program also seemed to fail as light levels dropped and the idea was to take a time exposure to show earth movement which it now seems will need manual timing with cable shutter release but would like to here what others have found when using the camera controlled by the PC?
There have been some plus points I have found how to set camera to auto set ISO 100 - 1600 rather than 100 - 400 and putting setting into the USER mode was something I have not considered before these experiments and also the setting of where the camera focused to was not understood by me until playing with the PC controls.
Minus point is because these setting are retained after disconnection with PC setting to Jpeg rather than RAW means the dynamic range is much reduced and I have got use to using the higher dynamic range offered when recording images in RAW.
As to if the Casio EX-Z600 can be controlled direct by the PC I don't know?
