Cutting 6mm ply
4 Sep 2016
Hi everyone,
I'm just after some advice if that's okay. I need to ply out a floor in 6mm ply, but I'm having a right hash of a time using a Stanley knife to be honest. I was just wondering whether it would be a bit over the top to use a jigsaw? I reckon I'd find that easier if I could find a way to do it.
If I used a jigsaw and propped the ply on a workmate bench, would that work? I'm using paper to template the floor, so would a jigsaw allow me to shape the ply to the intricate shapes?
My only other concern is the size of the ply; wouldn't it be almost impossible to clamp down a whole sheet of ply up on a workmate bench and comfortably saw through it?
Any advice would be much appreciated.
Raffa :)
You will be there for a month using a Stanley knife and will probably lose a finger using the jigsaw on 6mm ply "Propped up" against the workmate, can`t you use a handsaw or lay the ply on batons whilst you jigsaw. Why you using 6mm? It has little strength and will flex.
Yeah I guess so - that's a good idea. Would I be able to clamp the ply down on top of the workmate bench?
I cut 6mm plywood all the time with a knife. Not that hard. Better to use a concave blade.
You could use a Exakt saw. Very easy with them. But a jigsaw is fine with a short tooth blade in it.
Buy two Stanley workhorses, and a sheet of 12x3 22mm mdf flooring to use as a temp workbench (supported by the workhorses). A jigsaw is perfect for odd shapes. For straight lines, quickest way is to clamp a straight edge to the ply, then use either a jigsaw or (better) a small hand held circular saw with the depth set to approx 6.5mm.
It's worth cutting two 22mm thick bits of timber to just over the length and width of a plywood sheet to use as straight edges. Saves time in the long run.
I've ply boarded half my house this way.
Thanks so much for the advice - it's much appreciated. I've just ordered this pair of saw horses:
https://www.amazon.co.uk/dp/B009O8FW2A?ref_=pe_780071_41837251
Is it essential that I have four of these saw horses or will the pair be okay if I use the sheet of mdf/two lengths of wood? I've just ordered a pair but am worried that I'll need another pair to manage the whole sheet of ply. What do you reckon?
Cheers,
Raffa.
I just made do with 2 sawhorses and one sheet of mdf. It wasn't ideal, but I managed. 4 horses and 2 sheets of mdf just took up too much space.
I think also had a Workmate to support the overhanging edge.
