Cutting wood with two passes with Table Saw
Discussion in 'Wood / Woodwork / Carpentry' started by richard7761, 23 Feb 2012.
  1. richard7761
    21 Jan 2011
    372
    Thanks Received:
    Country:
    If the table saw will not cut right through the wood, then I presume you can do another pass to cut what was uncut in the first pass.
    So, that means a saw which is advertized to cut up to 35mm thick, can cut a 70mmm thick piece.
    What say? Rich.
  2. big-all
    12 Jul 2004
    15,891
    Thanks Received:
    1,096
    Surrey
    Country:
    yes and no
    you will need to remove the safety equipment [riving knife and guard] making it dangerous
    experienced people will do it unofficially as we cannot condone unsafe practices ;)
    what sort off wood are you talking about[hard wood/soft wood seasoned planed ]
  3. richard7761
    21 Jan 2011
    372
    Thanks Received:
    Country:
    It's the kind of wood I that I think you might find as joists or rafters. Sort of common all-garden original wood size 4" (100mm) x 2" (50mm).
    I've been looking at an inexpensive Titan SF88N5 200mm Table Saw at screwfix. That only cuts to 35mm.
    I've been using an electric planer to reduce the wood size to around 90mm x 40mm, but cannot get things square. I need a table saw.
    So, my wood is now 90mm x 40mm. I'll still not be able to cut 90mm, only about 70mm. But, I could saw the 20mm left uncut in the middle - I guess.
    I'm actually trying to square-up this wood. So, when I say saw the 20mm in the middle, I really mean plane.
  4. big-all
    12 Jul 2004
    15,891
    Thanks Received:
    1,096
    Surrey
    Country:
    i would not advise you to run any timber thats wet ror warped through a saw with full guards in place never mind without the guards in place
    what lengths are you talking about
  5. gregers
    28 Mar 2008
    6,302
    Thanks Received:
    499
    Sussex
    Country:
    only remove the safty gaurds of any machine for photographic purposes only. ;)
  6. richard7761
    21 Jan 2011
    372
    Thanks Received:
    Country:
    5 foot max.
  7. big-all
    12 Jul 2004
    15,891
    Thanks Received:
    1,096
    Surrey
    Country:
    norm has a lot to answer for :D :D ;)
  8. Jasonb
    20 Aug 2004
    2,420
    Thanks Received:
    94
    Surrey
    Country:
    If you are trying to clean up the wood by planing the faces and want to get the edges square then forget a saw and buy a planer/thicknesser.
    J[/quote]
  9. merlin50
    10 Jul 2010
    1,750
    Thanks Received:
    127
    Cornwall
    Country:
  10. Dave54
    21 Dec 2008
    1,599
    Thanks Received:
    189
    Country:
    That's the type of saw I've got. It's an excellent bit of kit. You'd have to have some work for it though to justify the money (although it's cheap enough there) space and 15A socket etc.
    That Titan saw is going to need fixing down for any heavy ripping. Ripping full depth like that isn't a recommended practice anyway, because of the dangers of work piece rejection, and at around 1 HP I doubt if that saw will have the power to do the job properly, particularly with no riving knife, which of course you wouldn't be doing anyway. . .
    Apart from any possible safety issues, resawing stuff like that by turning it over rarely gives good results. You often get a step between the two cuts.
    I'd find somebody with a suitably sized, and give them a drink to do it for me.
Loading...
Share This Page
