We have an old square brick built septic tank which has started overflowing (phew!) too regularly. Had it drained twice in last few weeks and jetted. Coy said there appeared to be blockage in soakaway, but should clear. Evidently it didn't and overflowing has begun again!
I have dug down and traced the clay pipe about 3 yds from tank and discovered cracked pipe which from which gallons gushed (phew again!). I suspect pipes are blocked further down.
Local Authority said over phone a replacement and further jetting may be sufficient, or will need to dig out all clay pipes and relay with perforated plastic. Large garden. it seems the single length (no herringbone) is about 50 yds They suggested this could be DIY but hard work. What does anyone think please?
