Do I need a carpet cleaning solution to clean carpets?
OM2
18 Jan 2007
Not sure if this is the right place to ask - but I'm pretty sure one of you guys will have an answer
I've purchased a Vax carpet cleaner
Question: do I HAVE to use 'carpet cleaning' solution?
How much better would this be than say fairy liquid?
I assume there MUST be some sort of difference - maybe the chemicals used are specifically for removing dirt from carpet fabric or something?
The thing is, carpet cleaning solutions cost a lot of money - even on eBay
If, it's advised to use a carpet cleaning solutions: where's the best place to buy from?
Thanks!
OM
M8 does carpet cleaning, swears by using DAZ washing up powder :D
awesome
does he do carpet cleaning professionally?
washing up powder or do u mean liquid??
just spotted a good price on vax cleaner for 5 packs at £20 - but i'd rather just go out and buy just one daz :)
thanks
Yeah he has one of those big machines.
Uses a cup of powder in the water tank.
He did my mothers house and my grandmothers, stunning results. Just shows how much dirt dogs drag in lol.
  • Thanks
Reactions: OM2
awesome. thanks. i'm convinced now.
won't bother buying the vax special washing thing now.
given u a thanks on the forum :)
Now you post! Just after I hired a Rug Doctor from Homebase at about £20 for the hire and £11 for the special cleaner :mad:
:D
Did a nice job though, I have to say. I also used it on what me and my girlfriend call the Quick Come Coutch, (don't ask) :D
It came up like a treat. (the coutch that is). I don't know why they have a different fluid specifically for furniture because it worked just fine.
Let us know how you get on with the Daz, presumably any Daz-like product will do?
M8 said he had tried a few and that was what he felt was the best.
Probably a bit late but if you use anything other than Vax cleaning solution it will void your guarantee!
Having said that you can't use anything that foams (ie fairy liquid) - hence I guess washing powder being good -that's low foaming.
(Know this cos my daughter split bubble bath on the carpet ...it was a nightmare - couldn't get rid of it! - just filled the dirty water tank with foam until it cut out - even months after I couldn't clean that bit of the carpet! in the end I literally poured water on it (knew not above any electric fittings ) and sucked that up and even that foamed like hell - carpet now replaced anyway - thank god!)
I found buying the vax detergent stuff directly from them - in bulk to save postage - worked out cheaper than ebay -but that was a few years ago - (I did do bulk! and don't wash carpets very often -still have some)
Also I read somewhere you should rinse with clean plain water after washing to rinse out the detergent -otherwise it leaves a sticky residue which attracts more dirt...trying this I found just water brings up a heck of a lot of dirt - don't bother with detergent sometimes...
I used Cif to do a little mat after running out of Rug Doctor solution on the main carpet...and it came up much cleaner. Not sure how it would fair on every type of carpet though.
