I know that similar questions appear in the forum already, but having read through lots couldn't find what I was looking for. I hope that someone can provide me with best solution.
My current setup is as follows:
The Consumer Unit fitted with B32 MCB is connected via 6 mm2 T+E to a 45A cooker switch (Including 13A socket) fitted above the worktop. The cooker switch is then connected via 6 mm2 T+E to a double socket. Both the current single oven and gas hob are plugged directly in to the double socket.
My new Double built under oven rated at 4.5 - 4.9 kw (according to the back plate) and therefore requires hard wiring. the new gas hob includes a 13A plug. The question is as only one 6 mm2 cable is available, is it possible to connect both appliances using the same cable. If so what is the best method of doing this?
Any help with this would be appreciated
