Drain off cock washers
26 Apr 2011
isle of Lewis
Hi guys well up here on the isle of Lewis we are having fun(not) with grant boilers springing leaks blowing off
pressure switches and generally pix ing water out all over.One prob I have is trying to source the little rubber
washers out of the drain off cocks these are rarer than hens teeth I've tried all over.
Please chaps does anyone have any ideas many thanks in advance.Bob
I stopped fitting Grant oil boilers, sick of them leaking & Grant not giving a sh.t.
YEs sir dick I agree but we've got loads up here and talk about leak never seen owt like it.At the moment I've got 8 all with leaks,I've took off pipes and resealed them I've replaced pump valves,air vents.I have got 2 waiting for plate heat exchangers,and to cap it all I was called today to look at one with the back blown out full of crap.The firm who put it in no flush no water treatment,no return filter and I don't think inhibitor put in.Who'd be an engineer.Bob
Grant must save their best boilers for the Midlands. With a 2.5 bar pressure relief valve, they should be better than other boilers as regards leaks. Perhaps bad installation is the main culprit, as with the example you quote.
