I'm building a shed type lean to thingy on the end of my kitchen. At the moment I have the roof up and am looking at the walls now. The current yard (concrete) has a slight slope to the house. To keep wood from contacting the ground I was going to support the struts to the roof on a brick and then put some temporary "shoring" <-spelling? up and pour concrete in (6:1 mix) that would encase the posts whilst them being off the ground and then panel the walls above this. The dwarf concrete wall would be approx 200mm thick and 300mm high to 400mm high at the lower end of the yard.
After this I will then be laying a screed inside the shed to about a depth of about 150mm (I was going to loose lay rubble for about half this depth to reduce the concrete required).
My questions are...
a) Does this plan sound ok?
b) Will I need to use some sort of visquine or similar under the walls and or under the screed?
Cheers for your help,
Ian.
My questions are...
Ian.
