earth bonding to gas meter
16 Jun 2004
is it allowable to earth a gas meter to earth, using a earthing rod as there is no earthing on it at the moment & the meter is on the floor in the basement & the consumer unit is on the second floor, also there fitted carpets through the house ! any thoughts.
Run the earth cable outside the house in black plastic conduit.
Secure - I assume you mean run the cable outside in conduit and then back in to the MET, not outside to a rod?
Also, with such a long distance, would you advise 16mm²?
I never uprate the bonding size with length - its for current not volts really. NIC was happy with a 40m run of 25mm on an 800amp TN-s system.
Incidently, extraneous metal parts can be used as a CONDUCTOR under certain conditions. NOT NOT NOT for a diyer to decide though.
A gas bond can deffinantly NOT NOT NOT be earthed to a rod.
Is the water main nearer to the gas meter?? If this is bonded to the correct size at present, you can pick up from there. BUT you must keep the cable continuous by crimping. See drawing.....
Ban
Yes, to the MET, not to a rod.
Personally I wouldn't use 16mm2, but there's no harm. Some recommend 16mm2 if supply is PME....
It would be fun to loop round the screws of an earth clamp....
Talking of which, wouldn't it be great if you could buy ones that had a tag which actually said:
WARNING
blah blan blah
:LOL:
