I have a metal dimmer switch with holes marked L1, L2,a wavy line and a gold screw for the earth. The wires in the wall are black, red and a bare wire that is connected to the metal box.
Following advice in the other threads I connected the red wire to the wavy line, the black wire to L1 and left the bare wire connected to a screw on the metal box. It works fine.
Since it is a metal dimmer it came with a transparent gasket which I put between the swith plate and the wall as instructed. My questions are:
1. Assuming the bare wire is earth shouldn't it have a green/yellow cover and should I leave it connected to the metal box?
2. Is the gasket necessary? - it looks stupid.
3. Shouldn't the switch have come with a short green/yellow wire to connect the earth terminal on the switch plate to the screw on the metal box?
Thanks.
Thanks.
