earth wire
13 Mar 2004
we live in an ex-authority house which is almost 40 years old. I want to replace all the lightswitches - which are the original plastic curved fronted ones - with brushed steel switches. Having taken off the cover of the switch in the hallway, there is no earth wire in the box behind. Clearly there needs to be an earth with the metal fixing. What can I do about it? Is there a way I can sort it out without calling out an electrician?
Well - you, or someone, needs to run an earth cable to each light switch & fitting, and they should all be connected together and connected back to the earth terminal in your CU or fusebox. I don't know whether this is something that you would feel comfortable with doing yourself, or if you need an electrician, but I think that you should get one of those anyway to inspect your entire installation.
It is nearly 40 years since it became compulsory to have an earth conductor in lighting circuits, which would fit with the age of your house, so there's a good chance that all of the wiring is 40 years old. Even if not rubber insulated, it may well have multi-stranded wires (which might not be able to cope with modern appliances), no main or supplementary earth bonding, no RCD for sockets which might be used to supply outdoors, and so on.
I must concur with Ban on this, get a Contractor (Compnay or Self-Employed) to come in and do a full Inspection and Test of the entire Installation.
That way you will certainly have a clear picture of the situation you are faced with.
Also, I fear that I might, in the words of our glorious leader, have misunderestimated what you need to do. I'm pretty sure that you couldn't just add a separate earth cable to the lighting circuit, at least, not without putting it in conduit, and that what you'd actually have to do would be to rewire it with twin & earth cable. I might be wrong - I know you need mechanical protection for single cables used for live & neutral, but I don't know about earths.
Ban, you are correct, you could not simply add an Earth to the circuit..didn't say anything as you suggested a rewire.
By the time you spend money updating the circuits and the rest of the installation to comply, a rewire will be cheaper in the long run.
(Read this with a US accent)
Sorry, folks, guess I was being a dumb-ass not picking up on that one.
See y'all!!
just wondering whats the situation with all the people that have installed metal light fittings that don't have earths?i am sure every leccy that has been asked to fit one dos'nt rewire the house.
(i cant quite think of the right word, but the gist is)
an electrcian is saying everything is ok, safe and up to standard, if it is not you must make it so it is
you also know where the door is that you came in.
If any Electrician fits a metal anything to any installation that does not have an Earth, he should be prosecuted for gross negligence.
He should state to the Home Owner.
" I am sorry to inform you but your current installation does not meet currently enforced regulations to BS7671:2001, as such I am unable to undertake the work you requested unless you give me the go ahead to bring the installation up to date. I appreciate this is an unforseen cost and because of this I will supply you with a quote for the works necessary so you may consult other contractors with regards to this. I will be in touch forth with regarding the quote, have a nice day"
(Words to that effect anyway)
the reason i asked is i have just moved into a property and was going to change a metal light fitting left by the previous owner but there were no earths (i know it will need a rewire in the near future)the previous owner assures me they were fitted by an electrician,and so it made me think there must be hundreds of thousands of houses like this with lights fittings fitted by electricians.
In the event of an installation not being up to standard, can an electrician do the work requested, but state on the completion cert. that the problems exist and get the customer to sign it? Does this pass the responsibility on to the customer?
