ecotec f 75 fault.
29 Apr 2011
London
Hi Guys.
I was called out to an ecotec 824 leaking water from underneath. After investigating found leak to be coming from gasket between pump head and housing. Struggling to find a replacement gasket (surprisingly), but have manged to stem the tide until i find a replacement. The boiler is also displaying the f 75 fault code. i have replaced the sensor and i know the pump is not dry and pressure is above needed. any ideas?
you need to change the pump first. Its not the gasket leaking its the pump internals. Could be and likely to be the pump causing the F75. Join the CC and can give you the full run down on this model.
Appreciate the help thanks, but i'm new to this. Whats the cc to join?
