Electric shower inlet fitting
10 Dec 2009
Middlesex
Im soon to be changing my electric shower that died recently
As can be seen in the photo the inlet comes from a plastic pipe directly down to the brass fitting on the unit
The replacement unit im looking at getting has either a right or left side water inlet, hence ill need to fit an elbow to the inlet pipe.
Can anyone recommend the correct and most suitable type of elbow to fit the plastic supply piipe and the inlet on the shower unit
15mm compression elbow - the nut on existing brass fitting is the same - try and get an elbow with copper olives, or buy a few spares. Leave the old nut+ olive in situ. New elbow body+ olive into shower.(y)
Thanks Nige, wasn't sure if i was supposed to only use a push fit type elbow with that plastic pipe hence my post. Ive got a bag of copper olives somwhere in the garage so will use them.
Cheers
