Electrolux oven door seal
9 Feb 2010
Worcestershire
We have an Electrolux electric double oven, Model EOD983X2 / 944171091 . Just recently we noticed that hot air was coming out from around the main oven door. After checking the door seal and finding it to have deteriorated somewhat I bought an authentic replacement from Electrolux. After looking at a few you tube videos, which made it seem really easy to replace the seal I decided to have a go. Whilst most seals are held in place by a clip at each corner this one appears to be almost welded in. You have to remove quite a few screws to get the frame at the front of the oven to move forwards so that you can take out the old and insert the new. The exploded pictures from the Electrolux website show that the main oven and the top oven have separate frames so that each seal may be replaced individually.. hmmm not quite the case on my oven. The frame has no split so all the screws from both ovens have to be removed. The problem is that one of the screws is behind the lower lip of the top oven door and I cant get at it to remove it. The frame seems pretty solidly stuck as with most screws removed you would expect a bit of movement in the frame. Not so in this case. I can't find any information on replacing the seal on this oven on the web, just the ones showing clips.
Any advice gratefully excepted and thanks for sticking with me on this painfully long post.
Al
