Engineered wood - HDF vs Plywood
Discussion in 'Floors, Stairs and Lofts' started by NickB_99, 9 May 2011.
  1. NickB_99
    25 Oct 2008
    1,094
    Thanks Received:
    120
    Cheshire
    Country:
    Hello all
    Hoping for some speedy comments on this.
    Received a delivery of engineered wood flooring today.
    It looks like the sample sent previously by them was not the same product as the delivery :evil:
    The sample I got was actually 14mm engineered with a dark oak veneer (about 3mm) and the backing looked like 4 or 5 plywood layers at 90degs to each.
    The wood when it arrived was only 10mm thick, looks about 2mm veneer and has an HDF backing.
    Both are a click system.
    Supplier wants a pic of the sample emailed, but is accepting it is probably their fault that the incorrect sample was sent. Assuming their fault, they will take back the original FOC, and option was to get the 14mm instead, but is £6/box extra.
    I prefer the slightly thicker of the two - and now for the question!
    I would have thought the matrix of plywood layers was better than the HDF (dimensionally stable, water resist etc). This was my take from the description of Engineered from the Sticky above.
    The supplier argues this is wrong and the HDF is the better product.
    :?: Any opinions if this is true?
    I can post a pic later if it will help when I'm home.
    TIA
  2. delberto
    31 Mar 2011
    90
    Thanks Received:
    4
    Hertfordshire
    Country:
    not an expert on this- I'm just a rough and slow chippy lol but real wood including ply can expand by 2-3mm per walking metre depending on conditions whereas hdf as used in laminate has a theoretical expansion of 1mm per walking metre. I just wonder how they manage to get the real wood to behave like the hdf it has been stuck to??
    If what you have received has a better guarantee and warranty than the plywood based product then it should be a better product if not then I'd be thinking the lower price was a clue to what you've been supplied with.... ;-D
    good luck
    • Thanks Thanks x 1
  3. NickB_99
    25 Oct 2008
    1,094
    Thanks Received:
    120
    Cheshire
    Country:
    I've had a further discussion with the supplier over the last couple of days.
    It looks like the wrong sample was sent out, due to it being incorrectly labeled at the supplier. Unfortunately the 14mm product is more expensive and an extra £6/m2.
    I have a couple of options here -
    - They are happy to arrange taking back the 10mm product & refund.
    - They are willing to supply the 14mm product in an exchange but do expect me to fund the full difference (ordered approx 13m2 so ~£80).
    From the website, they do sell the 14mm product at the price of the 10mm, when volume >100m2, so I guess I was cheekily hoping they would do the swap at no additional cost. Arranging for next delivery will require more time off work etc. Realistically, I wanted them to meet me half way but no joy so far.
    Is it common for samples to get muddled up? Anyone had any precedence of anything like this?
Loading...
Share This Page
