Enlarging Hole in Granite Worktop
27 Jun 2005
Hi There
We have an old Miele KM418 induction hob that has failed. I thought, just replace it with another unit... They don't make that model anymore and the hole is slightly too small for current models!
Our hole is currently 267 x 503 an it needs to be 272 (see image).
Any advice on how I should approach this? I can take the top outside (although it's very heavy).
My approach currently would be to mark it out with masking tape and using an angle grinder with a new diamond blade gently cut the 5mm out from the top surface downwards.
Any advise greatly welcomed.
Thanks in advance
Yes , it will work. I've done granite bar tops in pubs in situ in exactly that way several times over the years. It is dusty but it is probably less risky to do the job with the top I place (it is normal to bed granite tops onto silicone making them hard to remove) and with a vacuum hose wielding assistant. Be careful not to over cut
Thanks Job & Knock. Any advise on the angle grinder blade I have both 115mm and 230mm grinders. Would you use the smaller one? and would you buy an expensive blade or will a cheapish one do the job?
