For reference I have a radial circuit in my detached garage fed from a 2 way FCU (20A/5A). This FCU is fed by 4mm SWA connected from a dedicated FCU and 80A 30mA RCD in the house (cable run is approx 15mtrs). Three sockets and a fluorescent lamp are installed.
I would also like to have power in my summer house so I can have a ceiling fan/light combination and a socket for the occasional use of a radio or portable television. The distance between summer house and garage is approx 17mtrs
Is it reasonable to extend the existing 4mm SWA that feeds the garage, further on to the summer house? And by joining the extended SWA at the incoming terminals of the Garage FCU? Hence total cable run from the house to the summer house will be 32mtrs.
Is it also reasonable to have a garage CU (16A/6A MCBs c/w 63A 30mA RCD) installed in the summer house despite having a RCD back at the house? I had assumed that there should be separate MCB circuit protection for each outbuilding. While noting comments in the forum for and against additional RCDs, I thought a garage CU would be the most convenient all-in-one unit to have installed.
I am much obliged for any friendly advice.
Fred
Fred
