Hi all
i was looking for some advice in cutting down the 'humming' noise from a centrifugal fan located in a downstairs WC. This room has a plasterboard ceiling with noting in the cavity between the ceiling and the upstairs floorboards.
I feel the addition of insulation (glasswool) above on the ceiling may reduce the noise, as well as running a bead of silicon around the underside of the fan.
Are there any other ideas of how I may be able to reduce the noise / vibration. e.g. rubber matting above the ceiling???
Thanks in advance
P.s I have 3 low voltage halogen downlighters (12V 20W) in the ceiling also which require airspace for overheating.
Thanks in advance
