felt-tip stain on projector screen
20 Oct 2007
I have used a felt-tip on a regular projection screen. Has this ever happened to anyone? Is there a way to remove the stain without damaging the fabric of the screen?
depends what type of ink the felt tip uses.
try washing up liquid and water
hair spray
WARNING
use a cotton bud taht way you only do a small bit at atime
careless - water-based pen ink will wipe off with a damp cloth but can, if left a while, leave a tinted residue. Use a proprietary white-board cleaner (Eddings do one). Obtained from stationary merchant or educational supplier (they use a lot of white-boards in schools). Spirit-based ink is more problematic as you have to discover the correct solvent. If you have the offending pen, make a mark on a scrap of glass or plastic, let the ink dry well. Then you have to try a range of solvents to see which one'll work - meths, surgical spirit, white spirit/turps, lighter fuel, petrol, one of which should work (it's more often than not meths). If they all fail then you'll have to, as a last resort, use carbon tetrachloride. Of course there is no guarantee that the board surface won't be damaged by DIY attempts. Maybe a visit to your local janitorial supply company for help - they have vast ranges of all sorts of cleaners & solvents, and experience.
Thanks a lot!!
I've also been told that the WD-40 Magic Pen could do the trick. I also found an online tip that says that acetone might wear the marks away. I'll try everything on Tuesday. I'll also try to find "washable" felt-tips; you see, I have a projector screen and a regular white-board and I'm constantly using felt-tips...
Cheers.
